V7 Low-profile Articualted Mount
Quicklinx: BFL6WS00 Mfr#: WCL2DA99-2E
The heavy duty low profile articulating mount connects directly to your wall and holds large screen flat panel displays from 32" to 65". This high quality mount uses dual cantilever arms that allow you to move the display left or right and toward or away from the wall. The cable management channel keeps video and power cables organized. The "H" truss mounting bracket allows you to screw directly to wall studs for a safe and secure connection.
V7 mounting kit - Low Profile Mount - for flat panel - black
Mounting kit (Low Profile Mount) - wall-mountable
Mounting Components
Articulating wall mount
60 cm x 48.6 cm x 40 cm
Adjustments
Tilt
8.1 kg
Recommended Use
Flat panel
Recommended Display Size
32"-65"
VESA Mounting Interface
100 x 100 mm, up to 600 x 400 mm
Max Load Weight
45 kg
5-year warranty
60 cm
48.6 cm
40 cm
8.1 kg
AV Furniture
Mounting kit
Mounting Components
Design
Low Profile Mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
32"-65"
Adjustments
Tilt
Max Load Weight
45 kg
Adjustable depth, swivel adjustment
Limited warranty - 5 years
