V7 Elite Webcam 2000 USB/MIC
Quicklinx: 8KLGWS00 Mfr#: CS2021S-1E
Take instant communication to level with the V7 Elite Webcam. Featuring a true 2.0 megapixel sensor, auto focus, and a built-in microphone, the Elite offers HD video capture at up to 1600 x 1200 resolution. This V7 webcam offers vivid live images and sound, making it an ideal solution for virtual face-to-face meetings with important business and personal contacts. The V7 Elite Webcam has a universal clip/stand for easy mounting on desks or flat panel monitors.
The V7 Elite Webcam's true 2.0 megapixel sensor with auto focus allows for HD video capture up to 1600 x 1200 pixels at 30 FPS transmission speed, as well as 16-megapixel photos.
The universal clip stand allows for versatile positioning to accommodate all types of PC setups. There is a standalone option as well to make it easier to use the Elite with portable computers such as laptops.
  • Plug-and-Play
    When it comes to installation, it is easy and painless: The camera is Plug-and-Play. Connect the webcam to an available USB port. The computer recognizes the webcam and you are ready to start using it.
  • Built-in microphone
    A built-in microphone offers you great sound with noise prevention for clarity in a noisy room. The omni-directional microphone picks up sound from just about every direction equally to produce the same sound output from multiple directions at a uniform level. Even if you are moving about, you will always be heard.
  • Video performance
    The V7 Elite Webcam 2000 delivers crystal clear precision and superb image quality in normal room lighting. It allows you to shoot videos in HD quality and capture images up to 2-megapixels. The webcam has a premium autofocus feature that keeps your images sharp and intelligent face tracking which gives you the freedom to move around without distorting the image.
V7 Elite Webcam CS2021S - webcam
Webcam
Audio
Yes: built-in microphone
7 cm x 2.5 cm x 2 cm
74 g
Wired
Camera
Max Resolution
1600 x 1200
Frame Rate (max)
30 frames per second
Optical Sensor Type
2 MP
Focus Adjustment
Automatic
USB 2.0
Webcam
Audio Support
Wired
7 cm
2.5 cm
2 cm
74 g
Camera
Max Digital Video Resolution
1600 x 1200
Frame Rate (max)
Image Sensor
2 MP
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
1 x USB 2.0
