The Stereo Earbuds with Inline Mic provide comfort and high-fidelity sound quality with soft-bass, ideal for use with iPads, iPhones, MP3 players and any electronic device that supports a 3.5mm audio jack. The Earbuds feature a space-saving right-angle 3.5 mm jack, and soft rubber caps that ensure a comfortable fit. The inline mic is great for phone calls, and there is a built in play/pause, call answer/call end function so you can you use the phone and listen to music without missing a beat.
High-fidelity sound
Studio-quality sound and soft bass let you hear every note clearly wherever you are. -
Super comfortable
The soft silicone ear caps provide the upmost in-ear comfort for hours of listening enjoyment. -
Space-saving
Right-angle 3.5 mm jack saves space where you need it. Reduce the possibility of damaging the audio jack of your device - the right-angle jack keeps it out of your way. -
Step up to the mic
The In-line microphone has a button to pause and play your music and answer a call. The control you need, right at your fingertips.
- V7 HA110 - earphones with mic
- Product Type
- Earphones - wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- Pink
- Headphones Form Factor
- In-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Impedance
- 32 Ohm
- Microphone
- On-cable
- Controls
- Answer/end, play/pause
- 2-year warranty
- Product Type
- 2.1 cm
- 1.8 cm
- 1.2 cm
- 12 g
- Pink
- Recommended Use
Audio Output
- In-ear
- Wired
- Sound Output Mode
- Stereo
- Impedance
- 32 Ohm
Microphone
- On-cable
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
- Cable Details
- Headphones cable - 1.2 m
- FCC, RoHS
- Limited warranty - 2 years
