V7 Combo Card Reader with 3 USB Hubs (CU200-3EP)
Quicklinx: 8BCPWS00 Mfr#: CU200-3EP
The V7 Combo Card Reader combines three high-speed USB 2.0 ports with a card reader in an elegant system that delivers lightning-fast connectivity as well as file transfer capabilities. Just insert any multimedia format memory card and transfer data at 480 Mbps. As a hub, it easily connects your computer with all your USB-compliant devices, whether you're at home or on the road, such as digital cameras, digital camcorders, portable MP3 players, as well as peripherals such as scanners, printers, external hard drives and more. In addition, with the built-in mini-B USB cable, you can charge and synchronize your mobile phone with your computer more easily than ever.
V7 CU200 Combo Card Reader - card reader - USB 2.0
Card reader - external
Supported Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, miniSD, RS-MMC, microSD, Memory Stick Micro (M2)
Host Interface
USB 2.0
Silver
Built-in USB hub
Host Interface
USB 2.0
Silver
Built-in USB hub
68 mm
37 mm
11 mm
3.2 g
Memory Card
(max)
Additional Ports
1 x USB 2.0
Apple MacOS X / MacOS 9.1, Microsoft Windows 98/2000/XP/Vista/7
Plug and Play, C-Tick, RoHS, WEEE
