V7 Bluetooth wireless headset looks good and are so pumping you'll think you're standing in the middle of a club. Impress your crew with the easy one tap connection that lets you pair up with any NFC enabled Bluetooth smartphone, tablet, notebook or Apple's line of Bluetooth products. You'll be over the top when receiving incoming calls "hands free" by tapping the headphone to pause the music and answer with the built-in microphone. You can even change tracks, or adjust the volume without ever touching your phone or music device. The soft padded, contoured, ear pads are foldable so you can pop them in their custom tote bag and bounce whenever you need to.
- V7 Bluetooth Wireless Headset - headset
- Product Type
- Headset - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics, computer
- White
- Headphones Form Factor
- On-ear binaural
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Built-in
- Controls
- Volume, Push to Talk (PTT), play/pause
- Product Type
- 19 cm
- 6.5 cm
- 16.5 cm
- 320 g
- White
- Recommended Use
Audio Output
- On-ear binaural
- Foldable
- Wireless
- Bluetooth
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
Microphone
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB
- Included Accessories
- Carrying pouch
- Cable Details
- USB charge cable
- FCC, WEEE
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 360 mAh
- Run Time (Up To)
- 10 hour(s)
