Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 feet range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. The powerful 2.5 W speakers have a built-in passive radiator woofer for deep base. The USB rechargeable built-in battery provides longer uninterrupted sound while you're on the go.
- V7 SP6000 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- Frequency Response
- 80 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - 2.5 Watt - 80 - 20000 Hz - active
- White
- Power Options
- USB charging, USB powered
- Battery
- Speaker battery rechargeable - lithium polymer
- 14 cm x 6.6 cm x 9.3 cm
- 350 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- White
Speaker System
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- 80 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 3.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume, call answer
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 2.5 Watt - 80 - 20000 Hz CFR - active
- Driver Details
- Speaker: 2 x full-range driver , Speaker: Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
- Included Accessories
- Micro-USB cable
- Power Source
- Battery
- Options
- Rechargeable - lithium polymer
- Capacity (Ah)
- 3600 mAh
- Run Time (Up To)
- 16 hour(s)
- 14 cm
- 6.6 cm
- 9.3 cm
- 350 g
- Limited warranty - 2 years
