V7 hub works with all types of USB compliant devices including digital cameras, video cameras, scanners, joysticks, and more. With Plug-and-Play, hot swapping features, the hub allows attaching and removing of USB devices without reconfiguring settings or turning the computer system off. The high speed hub allows multiple high-performance USB 2.0 peripherals to connect to the PC for effective and efficient productivity.
- V7 HU720-3EP - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x USB 2.0
- USB 1.1, USB 2.0
- 6.9 cm x 6.9 cm x 2.4 cm
- 55 g
- Black
- System Requirements
- Apple MacOS X / MacOS 9.1, Microsoft Windows 98/2000/XP/Vista/7
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 7 x USB 2.0
- USB 1.1, USB 2.0
- 7 x USB 2.0 Type A , 1 x USB 2.0 Type A
- Black
- Cables Included
- 1 x USB cable
- Plug and Play, C-Tick, FCC, RoHS, WEEE
- OS Required
- 6.9 cm
- 6.9 cm
- 2.4 cm
- 55 g
