V7 2GB DDR3 SODIMM 1066MHZ CL7
Quicklinx: BCP5WS00 Mfr#: V73V2GNYBGI
Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
V7 - DDR3 - module - 2 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Unbuffered
10 years warranty
2 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
10 years warranty
