V7 2GB DDR2 SODIMM 800MHZ CL6
Quicklinx: BDP7WS00 Mfr#: V72V2GNXNFI
Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
V7 - DDR2 - module - 2 GB - SO-DIMM 200-pin - 800 MHz / PC2-6400 - unbuffered
Memory module
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
10 years warranty
2 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
10 years warranty
