V7 27" 1920x1080 5MS VGA HDMI LED Monitor with Speakers
Quicklinx: BN4YWS00 Mfr#: L27000WHS-9K
The V7 27" LED monior is designed with style, high screen performance and environmental features for home, work and everything in between, the L27000WHS, utilizes a low power LED backlight and saves on space while giving you a sharp, dazzling view in Full HD at high resolution. With stunning screen appeal, you will have a sharp, detailed, Full HD view while surfing the internet, working on projects, editing videos or streaming shows online. High screen performance includes 30,000,000:1 dynamic contrast ratio, 200 nits brightness, 5 ms response time, plus the low power LED backlight helps reduce the environmental footprint. This sleek LED widescreen monitor is a great value and looks sharp on every desktop. With both a VGA and HDMI input you are sure to enjoy the highest resolution possible.
V7 L27000WHS - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
30000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
57.5 cm x 18 cm x 49.3 cm
5.97 kg
United Kingdom
FCC, RoHS, WEEE
3-year warranty
Display Type
Energy Class
Class A+
33 kWh
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
57.5 cm x 18 cm x 49.3 cm - with stand
5.97 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
FCC, RoHS, WEEE
United Kingdom
Input Voltage
AC 120/230 V
22 W
On / Off Switch
Included Software
Drivers & Utilities
Apple MacOS X, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 or later
Dimensions & Weight Details
With stand - width: 57.5 cm - depth: 18 cm - height: 49.3 cm - weight: 5.97 kg , Without stand - width: 63.2 cm - depth: 4.7 cm - height: 38.6 cm
Limited warranty - 3 years - pick-up and return
