V7 23.6" Privacy Filter
Quicklinx: BCL0WS00 Mfr#: PS23.6W9A2-2E
Hurry, only 1 left in stock!
£58.25 ex VAT
£69.90 inc VAT
V7 Privacy Filters are excellent for open, high-traffic environments or wherever on-screen data needs to be kept private. Screen data is visible only to persons directly in front of the monitor without blurring or distortion. The filter darkens on-screen information when viewed from the side.
The high-gloss finish sharpens contrast and helps to protect fragile LCD screens from scratches and damage. V7 Privacy Filters are easy to attach and remove, and can be left in place even when your notebook computer is closed.
V7 Privacy Filter - display privacy filter - 23.6" wide
Display privacy filter
Display Screen Size Compatibility
23.6" wide
52.1 cm x 0.025 cm x 29.2 cm
23.6" wide
52.1 cm - 0.025 cm - 29.2 cm
Display Filter
Scratch Resistant
Brand: V7
