V7 21.5" 1920x1080 5MS VGA DVI-D LED Monitor with Speakers
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: BN4WWS00 Mfr#: L21500WDS-9K
The V7 Full HD LED monitor, provides superior image quality with vivid colors and life-like images. V7 LED backlight technology saves up to 40% energy and yields blacker blacks, pure white and more clearly defined grays for a vivid picture making it the perfect choice for home or office use. With vivid colors with a 1920x1080 Full HD resolution, 16:09 aspect ratio, 1,000,000:1 contrast ratio, 200 nits brightness, and many customizable settings to fit your needs. The L21500WDS provides for more desk space with its small desktop footprint, and looks great with a glossy bezel. The widescreen monitor is easily wall mountable and with both a VGA and DVI-D output you are sure to enjoy the highest resolution possible. The V7 LED monitor comes fully equipped with built-in on-board speakers for the complete audio- video experience.
V7 L21500WDS-9K - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
52.4 cm x 18 cm x 36.6 cm
3.29 kg
English / United Kingdom
FCC, RoHS, WEEE
3-year warranty
Display Type
Energy Class
Class A+
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Slim bezel design
Glossy black
52.4 cm x 18 cm x 36.6 cm - with stand
3.29 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , VGA (HD-15)
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
FCC, RoHS, WEEE
Input Voltage
AC 120/230 V
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Dimensions & Weight Details
With stand - width: 52.4 cm - depth: 18 cm - height: 36.6 cm - weight: 3.29 kg , Without stand - width: 52.4 cm - depth: 4.7 cm - height: 29 cm
Limited warranty - 3 years
