Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
- V7 - DDR - module - 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR SDRAM - DIMM 184-PIN
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Unbuffered
- 10 years warranty
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR SDRAM
- Form Factor
- DIMM 184-PIN
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 184-PIN
- 10 years warranty
