Urban Armor Gear Rugged Workflow Case for iPhone 12/12 Pro - White/Grey
Quicklinx: GZVWWS00 Mfr#: 114022BW4130
Introducing the UAG Rugged Workflow Case for the iPhone specifically designed for use in hospitals, clinics, and other healthcare environments. With a built-in hot-swappable battery pack and charging accessories, it provides nurses and health professionals uninterrupted 24/7 performance out of your iPhone device.
The case facilitates precise data and barcode capture using the iPhone's powerful built-in camera. Maximize efficiency and speed in the most demanding healthcare environments. Ideal for scanning patient ID bracelets, medication, charts, vials and for mobile data entry.
MIL-STD 810G and medical wipe certified, this case has passed rigorous testing for 12 feet (4m) drops to help protect your device against contaminants and accidental drops. The case features a built-in hand strap for optimal portability, and integrated charging pins for convenient on-the-go charging with the optional charging cradle.
Built with durable premium materials, this fully ruggedized case is designed to be used in almost any environment. This case is functionality and protection in perfect harmony.
UAG Rugged Workflow Case for iPhone 12/12 Pro - White/Grey - battery case for mobile phone
Battery case for mobile phone
7.92 cm x 2.44 cm x 15.34 cm
190 g
Material
Polycarbonate, thermoplastic polyurethane (TPU)
Grey, white
1-year warranty
Apple iPhone 12, 12 Pro
7.92 cm
2.44 cm
15.34 cm
190 g
Rugged
Material
Grey, white
Carrying Case
Battery case
Recommended Use
For mobile phone
Protection
Impact protection
Carrying Strap
Hand strap
Wireless charging support, slim fit
FCC, RoHS, MIL-STD 810G, MSDS, CEC, UN38.3
Min Temperature
-10 °C
Max Temperature
45 °C
Max Height of Drop Protection
3.6 m
3000 mAh
1 year
