You won't have to choose between style and protection with Lucent iPad case. A modern and sophisticated translucent body with contrasting dot pattern folio cover/stand protects your device from any unexpected drops. Essential for working from home, the office, or on the go. Progressive microdot design gives effortless flair to this classic style.
Stylish
The iPad Air case features a stylish, modern, and sophisticated translucent body with contrasting allover dot pattern folio protection to protect your device from any unexpected drops. -
Folio cover
Featuring an auto wake/sleep folio cover that doubles as an adjustable stand. -
Slim feature
Super slim, feather-light composite construction featuring an armor shell and impact-resistant soft core to protect against impact and accidental drops. -
Mobility and protection
Designed with mobility in mind, has a comfortable in-your-hand feel without being slippery. Raised camera bevel and all-around protective screen surround to protect lens and screen from scratches.
 - [U] Protective Case for Apple iPad Air 10.9-inch (2022) - Lucent Black - flip cover for tablet
- Product Type
 - Flip cover for tablet
- Screen Size Compatibility
 - 10.9"
 - 20.32 cm x 2.54 cm x 26.67 cm
 - 390 g
- Material
 - Polycarbonate
 - Black
 - Limited lifetime warranty
- Designed For
 - Apple 10.9-inch iPad Air (4th generation, 5th generation); 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation)
 - 20.32 cm
 - 2.54 cm
 - 26.67 cm
 - 390 g
- Material
 - Polycarbonate
 - Black
Carrying Case
 - Protective cover
- Recommended Use
 - For tablet
 - 10.9"
- Protection
 - Antimicrobial, drop protection
- Cover Type
 - Flip cover
- Open Type
 - Side
- Additional Compartments
 - Apple Pencil
- Cover Features
 - Stand function
 - Medical Grade, MIL-STD-810G 516.6
- Max Height of Drop Protection
 - 3.05 m
 - Lifetime
- Designed For
 - Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation)
