Urban Armor Gear Plyo Rugged Case for iPad Mini (6th Gen, 2021) - Black/Ice
Quicklinx: GRDTWS00 Mfr#: 123282114043
Colour: Black, Ice
£20.86 ex VAT
£25.03 inc VAT
Deciding between protection or looks is a thing of the past. Translucent and minimalist design packed with protection and utility. Featuring an auto wake/sleep folio cover that doubles as an adjustable stand and Apple Pencil holder so you can work or play on the go. Along with a protective screen surround to guard against cracks and scratches. Slim, sleek, and keeps up with daily travels and accidents. The Plyo Series.
  • Lightweight with strong impact
    Feel confident with the case's light composite construction that combines an impact resistant core with air-soft corners that can withstand whatever your next adventure throws at you.
  • Military drop tested
    UAG cases have been designed to withstand the rigors of the daily grind. Each case has been drop tested to the Military Standard, meaning the cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
  • Tested
    Tested and certified to protect your device from materials used in the medical field. UAG Plyo series have undergone 168 hours of medical grade testing to see the change in mass of the material before and after their exposure to cleaners.
UAG Rugged Case for iPad Mini (6th Gen, 2021) [8.3-inch] - Plyo Black/Ice - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
8.3"
21.1 cm x 1.75 cm x 14.3 cm
191 g
Black, ice
1-year warranty
Apple iPad mini (6th generation)
21.1 cm
1.75 cm
14.3 cm
191 g
Black, ice
Carrying Case
Protective cover
Recommended Use
For tablet
8.3"
Protection
Impact protection, drop protection
Cover Type
Flip cover
Additional Compartments
Apple Pencil
21.29 cm x 1.78 cm x 14.61 cm / 240 g
Cover Features
Stand function
MIL-STD 810G 516.6
1 year
Colour: Black
Colour: Ice
Brand: Urban Armor Gear
