Urban Armor Gear Plyo Ice Rugged Case for iPhone 13 Pro Max 5G - Magsafe Compatible
Quicklinx: GP5NWS00 Mfr#: 113162114343
Deciding between protection or looks is a thing of the past. The translucent Plyo Series combines advanced military tested drop protection with a minimalist aesthetic creating beautiful everyday armor and security for your phone. Redefining bulky cases without compromising protection.
  • Lightweight with strong impact
    Feel confident with the case's light composite construction that combines an impact-resistant core with air-soft corners that can withstand whatever your next adventure throws at you.
  • Military drop tested
    UAG cases have been designed to withstand the rigors of the daily grind. Each case has been drop tested to the Military Standard, meaning the cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
  • Tested
    Tested and certified to protect your device from materials used in the medical field. UAG Plyo series has undergone 168 hours of medical grade testing to see the change in mass of the material before and after their exposure to cleaners.
UAG Rugged Case for iPhone 13 Pro Max 5G [6.7-inch] - Plyo Ice - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
Screen Size Compatibility
6.7"
8.38 cm x 1.27 cm x 16.3 cm
40.8 g
Ice
1-year warranty
Apple iPhone 13 Pro Max
8.38 cm
1.27 cm
16.3 cm
40.8 g
Package Type
Retail
Ice
Carrying Case
Protective cover
Recommended Use
For mobile phone
6.7"
Protection
Drop protection, impact resistant
Cover Type
Back cover
12.07 cm x 1.91 cm x 19.69 cm / 120 g
MagSafe Compatibility
MIL-STD 810G 516.6
Max Height of Drop Protection
4.8 m
1 year
