Urban Armor Gear Plasma Series for Surface Book 2 /Book with Performance Base - Ice
Quicklinx: F5CCWS00 Mfr#: SFBKUNIV-L-IC
Urban Armor Gear products reflect the independent spirit of its designers and represent a dedication to superior quality and craftsmanship. The feather-light composite cases feature a hard outer shell and a soft impact resistant core. Although visually striking, the unique shape of the case also provides strength while minimizing size and weight. The design allows full access to your device's controls and ports, while openings are designed for problem-free snapshots and uncompromised audio. The marriage of these design elements and materials working in unison maximizes protection for your device. This case is compatible with Surface Book 2, Surface Book, & Surface Book with Performance Base, 13.5-inch Universal case.
UAG Rugged Case for Surface Book 2, Surface Book, & Surface Book with Performance Base, 13.5-inch Universal Case - tablet PC carrying case
Tablet PC carrying case
Ice (transparent)
24.13 cm x 3.18 cm x 32.26 cm
430 g
Notebook Compatibility
13.5"
Impact resistant MIL-STD-810G tested
Microsoft Surface Book, Book 2 (13.5 in)
24.13 cm
3.18 cm
32.26 cm
430 g
13.5"
Additional Compartments
Pen/stylus holder
Impact resistant
Ice (transparent)
MIL-STD-810G tested
