Urban Armor Gear Plasma Series for MacBook Pro 13" (4th Gen) - Ice
Quicklinx: F7TWWS00 Mfr#: MBP13-4G-L-IC
Hurry, only 1 left in stock!
£54.16 ex VAT
£64.99 inc VAT
Engineered to provide protection for an active mobile lifestyle, UAG brings you the first rugged MacBook Pro 13-inch that meets MIL-SPEC 810G-516.6 drop test standards. The patented composite design fuses a hard outer shell with soft impact resistant bumpers engineered to protect your MacBook Pro 13-inchfrom drop and shock. The unique 1-piece design and soft rubberized bumpers and bottom skid pads provide 360-degree protection from scratches and abrasions. With oversized ports and a low profile design that slips in and out of your bag, access is always fast and easy. Available in a clear translucent color, UAG's rugged and lightweight MacBook Pro 13-inch cases are sure to make you stand out from the crowd whether at work or the next expedition. Compatible with the MacBook Pro 13-inch (4th Gen, 2016-2018) with Touch Bar and Non-Touch Bar Model Numbers: A1708, A1706, A1989.
UAG Rugged Case for MacBook Pro 13? (4th Gen, 2016-2018) w/ or w/o TouchBar notebook top and rear cover
Notebook top and rear cover
Transparent, ice
Product Material
Rubber
31.6 cm x 22.43 cm x 2.31 cm
310 g
Notebook Compatibility
13"
Shock-resistant, abrasion resistant, drop-resistant, impact-resistant, scratch-resistant
Apple MacBook Pro 13.3" (Late 2016)
Product Material
Rubber
31.6 cm
22.43 cm
2.31 cm
310 g
13"
Transparent, ice
Urban Armor Gear Plasma Series for MacBook Pro 13 Bundle deal on Urban Armor Gear Plasma Series for MacBook Pro 13" (4th Gen) - Ice
£153.33
Brand: Urban Armor Gear
Price Range Ex VAT: 50 - 100
