Urban Armor Gear Plasma for Apple iPhone SE - Ice (Transparent)
Quicklinx: G5M7WS00 Mfr#: 112043114343
An excellent showcase of the dedication to superior quality and craftsmanship is the Plasma phone case. Finally, ultra-protection doesn't have to mean ultra-bulky. The Plasma Series has a feather-light composite case that features a hard-outer shell and a soft impact resistant core. The unique shape of the case provides strength while minimizing the size and weight that you usually see from a typical protective case. With the Plasma case you can visibly see the protection, its skid pad corners and strong honeycomb structure and at the same time feel the slim body in your hand.
UAG Rugged for Case for Apple iPhone SE (2020) - Plasma Ice - back cover for mobile phone
Back cover for mobile phone
Screen Size Compatibility
4.7"
Ice
Apple iPhone SE (2nd generation)
Package Type
Retail
Ice
Carrying Case
Protective cover
Recommended Use
For mobile phone
4.7"
Protection
Scratch-resistant, impact protection, drop-proof
Cover Type
Back cover
12.07 cm x 1.91 cm x 19.69 cm / 100 g
MIL-STD 810G 516.6
