Metropolis SE Series features a tough and rugged silhouette that provides your tablet with unbeatable protection. Featuring a featherlight composite construction and a soft, impact-resistant core to shield your tablet from serious drops from serious heights. Impact-resistant corners to shield your tablet from scratches and dents from accidental drops or falls. The folio cover doubles as a stand to quickly transform your tablet into a laptop with ease. Soft touch and smooth PU exterior that can withstand the use of daily cleaning wipes. Thoughtful shoulder strap tether anchor points for the use of an adjustable shoulder strap for when your tablet is not in use or for transport. The perfect case for people that rely on their tablets on-the-go.
Ultimate on-the-go essential
Protect what matters with this on-the-go travel essential. With 360-degree protection and credit card storage, the Metropolis Series is perfect for wherever life takes you. -
Safeguard meets function
Maintain screen and device safety with an impact-resistant case engineered to uphold military drop-test standards and easily access touchscreen and ports. The soft felt-lined cover and water-resistant tactile non-slip grip exterior make for a good feel whether in the hand or tucked away. -
Military drop tested
Cases have been designed to withstand the rigors of the daily grind. Each case has been drop tested to the military standard, meaning cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
- UAG - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10.9"
- Material
- Polyurethane (PU)
- Black
- Designed For
- Apple 10.9-inch iPad (10th generation); iPad A16 Wi-Fi, A16 Wi-Fi + Cellular
- Package Type
- Bulk
- Rugged
- Material
- Polyurethane (PU)
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10.9"
- Protection
- Drop protection, impact protection, scrape protection
- Cover Type
- Flip cover
- Open Type
- Side
- Additional Compartments
- Apple Pencil storage
- Shipping Dimensions (WxDxH) / Weight
- 20.32 cm x 2.54 cm x 26.67 cm / 340 g
- Raised screen surround, impact-resistant corners, auto wake-up/sleep function, featherlight
- Cover Features
- Stand function
- MIL-STD 810G 516.6, Medical Grade
- Designed For
- Apple 10.9-inch iPad (10th generation) , Apple iPad A16 Wi-Fi, A16 Wi-Fi + Cellular
