Always using premium materials, the Metropolis series is built to withstand your everyday adventures. Functionality and protection in perfect harmony. The design provides 360-degree protection and allows full access to your device's controls and ports. Openings are designed for glare-free flash snapshots and uncompromised audio. The marriage of these design elements and materials working in unison maximizes protection for your device. Compatible with Model Numbers: A2378, A2379, A2461, A2462.
Ultimate on-the-go essential
Protect what matters with this on-the-go travel essential. With 360-degree protection and credit card storage, the Metropolis Series is perfect for wherever life takes you. -
Safeguard meets function
Maintain screen and device safety with an impact-resistant case engineered to uphold military drop-test standards, providing easy access to touchscreen and ports. The soft felt-lined cover and water-resistant tactile nonslip grip exterior make for a good feel whether in the hand or tucked away. -
Military drop-tested
UAG's cases have been designed to withstand the rigors of the daily grind. Each case has been drop-tested to the Military Standard, meaning the cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
- UAG Rugged Case for iPad Pro 12.9-in (5th Gen, 2021) - Metropolis Black - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 12.9"
- 22.5 cm x 1.65 cm x 30.2 cm
- 481 g
- Black
- 1-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (4th generation, 5th generation)
- 22.5 cm
- 1.65 cm
- 30.2 cm
- 481 g
- Package Type
- Retail
- Rugged
- Lining Material
- Felt
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 12.9"
- Protection
- Impact protection, drop protection, shock protection
- Cover Type
- Flip cover
- Open Type
- Side
- Additional Compartments
- Apple Pencil
- Shipping Dimensions (WxDxH) / Weight
- 24.77 cm x 1.91 cm x 30.48 cm / 580 g
- Cover Features
- Stand function, non-slip grip
- MIL-STD 810G 516.6
- Max Height of Drop Protection
- 1.22 m
- 1 year
- Designed For
