Urban Armor Gear Metropolis Rugged Case for iPad Pro 12.9-in (5th Gen, 2021) - Black
Quicklinx: GKT5WS00 Mfr#: 122946114040
Always using premium materials, the Metropolis series is built to withstand your everyday adventures. Functionality and protection in perfect harmony. The design provides 360-degree protection and allows full access to your device's controls and ports. Openings are designed for glare-free flash snapshots and uncompromised audio. The marriage of these design elements and materials working in unison maximizes protection for your device. Compatible with Model Numbers: A2378, A2379, A2461, A2462.
  • Ultimate on-the-go essential
    Protect what matters with this on-the-go travel essential. With 360-degree protection and credit card storage, the Metropolis Series is perfect for wherever life takes you.
  • Safeguard meets function
    Maintain screen and device safety with an impact-resistant case engineered to uphold military drop-test standards, providing easy access to touchscreen and ports. The soft felt-lined cover and water-resistant tactile nonslip grip exterior make for a good feel whether in the hand or tucked away.
  • Military drop-tested
    UAG's cases have been designed to withstand the rigors of the daily grind. Each case has been drop-tested to the Military Standard, meaning the cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
UAG Rugged Case for iPad Pro 12.9-in (5th Gen, 2021) - Metropolis Black - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
12.9"
22.5 cm x 1.65 cm x 30.2 cm
481 g
1-year warranty
Apple 12.9-inch iPad Pro (4th generation, 5th generation)
22.5 cm
1.65 cm
30.2 cm
481 g
Package Type
Retail
Rugged
Lining Material
Felt
Carrying Case
Protective cover
Recommended Use
For tablet
12.9"
Protection
Impact protection, drop protection, shock protection
Cover Type
Flip cover
Open Type
Side
Additional Compartments
Apple Pencil
24.77 cm x 1.91 cm x 30.48 cm / 580 g
Cover Features
Stand function, non-slip grip
MIL-STD 810G 516.6
Max Height of Drop Protection
1.22 m
1 year
