UAG's tempered glass screen shields are engineered to protect your display from scratches and abrasions even in the most demanding environments. The ultra-thin construction delivers precision touch sensitivity and pristine HD surface clarity. A special coating repels natural skin oils; limiting fingerprints and smudges that can compromise image resolution. Easily apply the screen shield at home with an applicator and cleaning kit. Your screen will always look clean, respond to your touch accurately, and deliver strong protection with the UAG Glass Shield. Couple the tempered glass screen shields with one of the cases to experience unparalleled protection on all your adventures.
9H strength glass
Protects your screen from scratches and abrasions even in the most demanding environments. -
Ultra-thin construction
Delivers precision touch sensitivity and pristine clear high-definition surface clarity. -
Special coating
Repels natural skin oil limiting fingerprints and smudges. -
Precision fit
Specifically designed for a perfect fit with UAG cases.
- UAG Screen Protector for iPhone 13 5G/13 Pro 5G [6.1-inch] - Glass Shield Clear - screen protector for mobile phone
- Product Type
- Screen protector - glass
- Intended For
- Mobile phone
- Protection
- Fingerprint-proof
- Package Content
- Screen protector, applicator, cleaning kit
- Product Material
- Tempered glass (9H)
- 10.9 cm x 1.3 cm x 19.3 cm
- 67 g
- Clear
- 1-year warranty
- Designed For
- Apple iPhone 13, 13 Pro
- Product Type
- Intended For
- Mobile phone
- Protection
- Fingerprint-proof
- Package Content
- Product Material
- 10.9 cm
- 1.3 cm
- 19.3 cm
- 67 g
- Clear
- 1 year
- Designed For
Urban Armor Gear Glass Shield Clear for Apple iPhone 13 5G/13 Pro 5G
