Urban Armor Gear Glass Shield Clear for Apple iPhone 13 5G/13 Pro 5G
Quicklinx: GLXSWS00 Mfr#: 143150110000
UAG's tempered glass screen shields are engineered to protect your display from scratches and abrasions even in the most demanding environments. The ultra-thin construction delivers precision touch sensitivity and pristine HD surface clarity. A special coating repels natural skin oils; limiting fingerprints and smudges that can compromise image resolution. Easily apply the screen shield at home with an applicator and cleaning kit. Your screen will always look clean, respond to your touch accurately, and deliver strong protection with the UAG Glass Shield. Couple the tempered glass screen shields with one of the cases to experience unparalleled protection on all your adventures.
  • 9H strength glass
    Protects your screen from scratches and abrasions even in the most demanding environments.
  • Ultra-thin construction
    Delivers precision touch sensitivity and pristine clear high-definition surface clarity.
  • Special coating
    Repels natural skin oil limiting fingerprints and smudges.
  • Precision fit
    Specifically designed for a perfect fit with UAG cases.
UAG Screen Protector for iPhone 13 5G/13 Pro 5G [6.1-inch] - Glass Shield Clear - screen protector for mobile phone
Screen protector - glass
Intended For
Mobile phone
Protection
Fingerprint-proof
Package Content
Screen protector, applicator, cleaning kit
Product Material
Tempered glass (9H)
10.9 cm x 1.3 cm x 19.3 cm
67 g
Clear
1-year warranty
Apple iPhone 13, 13 Pro
Intended For
Mobile phone
Protection
Fingerprint-proof
Package Content
Product Material
Tempered glass (9H)
10.9 cm
1.3 cm
19.3 cm
67 g
Clear
1 year
