- Unicol POZIMOUNT PZX3 mounting kit - for flat panel
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 54 cm 44 cm
- Recommended Use
- Flat panel
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm
- Max Load Weight
- 60 kg
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 54 cm
- 44 cm
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Max Load Weight
- 60 kg
