Imagine you could reach out and with a light touch, tilt your display anywhere through its range to suit your precise viewing angle. The ease of this is possible thanks to the patented POZIMOUNT tilt counterbalance mechanism. The tilt angle you choose is reliably set or can be changed whenever necessary. POZIMOUNT units can be direct wall fixed or used with any of the ceiling kits, swing-arm wall units or stands and trolleys.
- Unicol POZIMOUNT PZW3 mounting kit - for flat panel
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- Adjustable Width
- 20-45 cm
- Adjustable Height
- 20-41 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-57"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 300 mm
- Max Mounting Pattern Size
- 540 x 440 mm
- Max Load Weight
- 60 kg
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Adjustable Width
- 20-45 cm
- Adjustable Height
- 20-41 cm
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 540 x 440 mm
- 32"-57"
- Max Load Weight
- 60 kg
- Adjustable height, adjustable width
