The weather-resistant case is designed specifically for outdoor installations. Dual, omni-directional antennas on the UAP-Outdoor+ provides 360° wireless coverage.
- Ubiquiti UniFi UAP-Outdoor+ - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - outdoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Included Accessories
- PoE injector
- Power Over Ethernet (PoE) Supported
- PoE
- 8.3 cm x 3.7 cm x 20.5 cm
- 250 g
- Ruggedized Design
- Outdoor
- 8.3 cm
- 3.7 cm
- 20.5 cm
- 250 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 183 m
- Power over Ethernet (PoE), VLAN support, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, pole mountable
- Encryption Algorithm
- AES, TKIP, WPA2, WPA-PSK, WEP
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- 2 x 100Base-TX - RJ-45
- PoE injector
- IC, FCC
- PoE
- 8 Watt
- -30 °C
- 65 °C
- 5 - 95% (non-condensing)
