Ubiquiti Unifi AP-AC Pro Radio Access Point
Quicklinx: BRYTWS00 Mfr#: UAP-AC-PRO
Type: Radio access point
Connectivity: Wireless
Speed: 1300Mbps
Protocol: IEEE 802.11ac, IEEE 802.11n, IEEE 802.11a, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
Hurry, only 1 left in stock!
£122.17 ex VAT
£146.60 inc VAT
802.11ac PRO Access Point
The UniFi AC-Pro combines enterprise performance, unlimited scalability, and a central management controller. UniFi 802.11AC Dual-Radio Access Points (APs) have a refined industrial design and can be easily installed using the included mounting hardware.
The UAP-AC-Pro is easily accessible through any standard web browser, and the UniFi Controller software is a powerful software engine ideal for high-density client deployments requiring low latency and high uptime performance. Use the UniFi Controller software to quickly configure and administer an enterprise Wi-Fi network - no special training required. RF map and performance features, real-time status, automatic UAP device detection, and advanced security options are all seamlessly integrated.
Unlike traditional enterprise Wi-Fi systems that use a hardware controller, UniFi comes bundled with a non-dedicated software controller that can be deployed on an on-site PC, Mac, or Linux machine; in a private cloud; or using a public cloud service.
The UniFi 802.11AC Dual-Radio APs feature the latest in Wi-Fi 802.11AC MIMO technology. Intuitive UniFi Controller Software Configure and manage your APs with the easy-to-learn user interface. Build wireless networks as big or small as needed. Start with one (or upgrade to a three-pack) and expand to thousands while maintaining a single unified management system.
The UniFi AC Pro AP features the Wi-Fi 802.11ac, 3x3 MIMO technology in a refined industrial design and is ideal for deployment of maximum-performance wireless networks.
Deploy the UniFi AC Pro AP indoors or outdoors, in wireless networks requiring maximum performance.
Sporting a weatherproof design, the UniFi AC Pro AP features simultaneous, dual-band, 3x3 MIMO technology and convenient 802.3af PoE/802.3at PoE+ compatibility.
Up to 5X Faster with Dual-Radio 3x3 11AC MIMO Technology
The UniFi AC Pro AP supports simultaneous dual-band, 3x3 MIMO technology in the 5 and 2.4 GHz radio bands.
Versatile Design
The UniFi AC Pro AP is a gigabit, 802.3af-powered access point suitable for indoor or outdoor use.
* Designed for Optimal RF Performance
* Versatile Design
* The UniFi AC Pro AP is a gigabit, 802.3af-powered access point suitable for indoor or outdoor use.
* Scalable Enterprise Wi-Fi Management
  • Up to 5x faster with dual-radio 3x3 11AC MIMO technology
  • Versatile design
    The UniFi AC Pro AP is a Gigabit, 802.3af-powered access point suitable for indoor or outdoor use. You can easily replace a standard UniFi AP using the same mounting hardware.
  • Scalable enterprise Wi-Fi management
    The UniFi Controller v4 software is a powerful, enterprise wireless software engine ideal for high-density client deployments requiring low latency and high uptime performance. With its software-based capabilities, the UniFi virtual control plane allows for unlimited scalability under one centralized controller.
Ubiquiti UniFi AP-AC Pro - radio access point - Wi-Fi 5
Radio access point
External - outdoor, indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Concurrent devices: 200+ , BSSIDs per radio: 4
PoE injector
Power Over Ethernet (PoE) Supported
PoE+
DC 44 - 57 V
19.67 cm x 19.67 cm x 3.5 cm
350 g
Radio access point
Ruggedized Design
Outdoor, indoor
19.67 cm
19.67 cm
3.5 cm
350 g
External
Wireless
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Max Range Open Space
122 m
VLAN support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, 3T3R MIMO technology, ceiling mountable
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK, WEP
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
2 x 1000Base-T (PoE+) - RJ-45 , 1 x USB 2.0
PoE injector
IC, FCC
PoE+
DC 44 - 57 V
9 Watt
-10 °C
70 °C
5 - 95% (non-condensing)
Speed: 1300Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Compatibility: PC
Brand: Ubiquiti
