Ubiquiti UniFi 8 Port 60W Switch with 4 Port 60W PoE
Quicklinx: CQ78WS00 Mfr#: US-8-150W
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
41 In Stock
£183.33 ex VAT
£219.99 inc VAT
The fanless UniFi Switch delivers quiet yet powerful performance with its 10 independent switching ports. Sharing a total of 150 W PoE, eight Gigabit Ethernet ports offer 802.3af/at PoE+ or 24V passive PoE, and two SFP ports offer optical connectivity.
  • Versatile port configuration
    Eight Gigabit RJ45 ports offer different power output options: auto-sensing IEEE 802.3af/at PoE/PoE+ and 24 V passive PoE, and two SFP ports provide optical fiber connectivity options to support uplinks of up to 1 Gbps.
  • Sleek design and management
    The compact UniFi Switch can be placed on a desktop and integrates with the UniFi controller software for centralized management of your UniFi devices.
  • Enhanced enterprise switching
    The UniFi Switch supports VLAN tagging, port isolation, storm control, and guest control.
Ubiquiti UniFi Switch US-8-150W - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
Performance
Non-blocking switching capacity: 8 Gbps , Switching capacity: 20 Gbps , Forwarding performance: 14.88 Mpps
Reset button
IEEE 802.3af, IEEE 802.3at
23.5 cm x 20.4 cm x 4.3 cm
1.7 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
Reset button
Status Indicators
Port transmission speed, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+ - 34.2 W , 2 x SFP
Internal power supply
Power Provided
150 Watt
IC, FCC, RoHS, ETSI 300 019
23.5 cm
20.4 cm
4.3 cm
1.7 kg
-5 °C
5 - 95% (non-condensing)
Ports: 8
Managed: Yes
POE: PoE+
Brand: Ubiquiti
