TOUGHSwitch PoE delivers reliable passive PoE and fast 10/100/1000 Mbps connectivity to attached Ubiquiti devices and other devices that support passive PoE.
To connect your PoE devices, simply enable PoE in the easy-to-use TOUGHSwitch configuration interface. Each port can be individually configured to provide PoE, so both PoE and non-PoE devices can be connected.
- Ubiquiti TOUGHSwitch PoE Pro - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 150 W
- 24KV ESD Protector
- Power
- AC 120/230 V
- 21 cm x 18.5 cm x 4.1 cm
- 1.24 kg
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- PoE
- PoE Budget
- 150 W
- Processor
- X MIPS MIPS 24K: 400 MHz
- RAM
- 64 MB
- Status Indicators
- PoE, link/activity
- 8 x 1000Base-T RJ-45 , 1 x 100Base-TX RJ-45 management , 1 x USB 2.0
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 21 cm
- 18.5 cm
- 4.1 cm
- 1.24 kg
