Ubiquiti TOUGHSwitch PoE Pro 8 Oorts Managed Desktop Switch
Installation required? Contact us today!
Quicklinx: BJM9WS00 Mfr#: TS-8-PRO
TOUGHSwitch PoE delivers reliable passive PoE and fast 10/100/1000 Mbps connectivity to attached Ubiquiti devices and other devices that support passive PoE.
To connect your PoE devices, simply enable PoE in the easy-to-use TOUGHSwitch configuration interface. Each port can be individually configured to provide PoE, so both PoE and non-PoE devices can be connected.
Ubiquiti TOUGHSwitch PoE Pro - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
150 W
24KV ESD Protector
AC 120/230 V
21 cm x 18.5 cm x 4.1 cm
1.24 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
PoE
PoE Budget
150 W
24KV ESD Protector
X MIPS MIPS 24K: 400 MHz
RAM
64 MB
Status Indicators
PoE, link/activity
8 x 1000Base-T RJ-45 , 1 x 100Base-TX RJ-45 management , 1 x USB 2.0
Internal power supply
AC 120/230 V
21 cm
18.5 cm
4.1 cm
1.24 kg
