Featuring an omni antenna and single-polarity performance, the PicoStation is ideal for applications requiring indoor/outdoor versatility and a compact form factor.
Small size, versatile application use
The PicoStation M can be deployed as an access point or station in applications requiring a minimal installation footprint. -
Carrier-class throughput
The PicoStation M delivers up to 100+ Mbps real TCP/IP throughput. -
Durability to last outdoors
The robust, weatherproof case withstands harsh outdoor conditions. -
Advanced software technology
Ubiquiti's airMAX technology is proven in millions of deployments worldwide, exhibiting outstanding performance in outdoor environments. The TDMA airMAX protocol enables unprecedented scalability, high throughput and low latency in unlicensed, multipoint networks. -
Medium-range performance
The PicoStation M provides 360° coverage at a range of up to 500 m - suitable for a medium-range deployment.
- Ubiquiti PicoStationM2HP - radio access point - Wi-Fi, AirMax
- Radio access point
- Form Factor
- External - outdoor, indoor
- Processor
- 1 x Atheros MIPS 24KC 400 MHz
- RAM
- 32 MB
- Flash Memory
- 8 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, AirMax
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 3.9 cm x 2 cm x 13.6 cm
- 100 g
- Ruggedized Design
- Outdoor, indoor
- 3.9 cm
- 2 cm
- 13.6 cm
- 100 g
Processor / Memory / Storage
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 32 MB SDRAM
- Flash Memory
- 8 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 100 Mbps
- Frequency Band
- 2.4 GHz
- Max Range Indoors
- 200 m
- Max Range Open Space
- 500 m
- Firmware upgradable, wall mountable, pole mountable
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Directivity
- Omni-directional
- 1 x 100Base-TX - RJ-45 , 1 x aerial - RP-SMA
- FCC Part 15.247, RSS-210, IC, RoHS
- PoE
- 8 Watt
- OS Provided
- AirOS
- -20 °C
- 70 °C
- 5 - 95% (non-condensing)
