The UniFi AC Pro AP features the Wi-Fi 802.11ac, 3x3 MIMO technology in a refined industrial design and is ideal for deployment of maximum-performance wireless networks.
Up to 5x faster with dual-radio 3x3 11AC MIMO technology
The UniFi AC Pro AP supports simultaneous dual-band, 3x3 MIMO technology in the 5 and 2.4 GHz radio bands. -
Versatile design
The UniFi AC Pro AP is a Gigabit, 802.3af-powered access point suitable for indoor or outdoor use. You can easily replace a standard UniFi AP using the same mounting hardware. -
Scalable enterprise Wi-Fi management
The UniFi Controller v4 software is a powerful, enterprise wireless software engine ideal for high-density client deployments requiring low latency and high uptime performance. With its software-based capabilities, the UniFi virtual control plane allows for unlimited scalability under one centralized controller.
- Ubiquiti UniFi AP-AC Pro - radio access point - Wi-Fi 5
- Radio access point
- Packaged Quantity
- 5 (specifications are for single item)
- Form Factor
- External - outdoor, indoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Concurrent devices: 200+ , BSSIDs per radio: 4
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- DC 44 - 57 V
- 19.67 cm x 19.67 cm x 3.5 cm
- 350 g
- Packaged Quantity
- Ruggedized Design
- Outdoor, indoor
- 19.67 cm
- 19.67 cm
- 3.5 cm
- 350 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Max Range Open Space
- 122 m
- Capacity
- VLAN support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, 3T3R MIMO technology, ceiling mountable
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPA-PSK, WEP
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 3
- 2 x 1000Base-T (PoE+) - RJ-45 , 1 x USB 2.0
- IC, FCC
- PoE+
- Voltage Required
- DC 44 - 57 V
- 9 Watt
- -10 °C
- 70 °C
- 5 - 95% (non-condensing)
