Ubiquiti Networks WLAN Access Point 5 Pack
Quicklinx: C8J3WS00 Mfr#: UAP-AC-PRO-5
Type: Radio access point
Connectivity: Wireless
Speed: 1300Mbps
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11b + 1 more
Compatibility: PC
  • IEEE 802.11n
£509.02 ex VAT
£610.82 inc VAT
The UniFi AC Pro AP features the Wi-Fi 802.11ac, 3x3 MIMO technology in a refined industrial design and is ideal for deployment of maximum-performance wireless networks.
  • Up to 5x faster with dual-radio 3x3 11AC MIMO technology
    The UniFi AC Pro AP supports simultaneous dual-band, 3x3 MIMO technology in the 5 and 2.4 GHz radio bands.
  • Versatile design
    The UniFi AC Pro AP is a Gigabit, 802.3af-powered access point suitable for indoor or outdoor use. You can easily replace a standard UniFi AP using the same mounting hardware.
  • Scalable enterprise Wi-Fi management
    The UniFi Controller v4 software is a powerful, enterprise wireless software engine ideal for high-density client deployments requiring low latency and high uptime performance. With its software-based capabilities, the UniFi virtual control plane allows for unlimited scalability under one centralized controller.
Ubiquiti UniFi AP-AC Pro - radio access point - Wi-Fi 5
Radio access point
Packaged Quantity
5 (specifications are for single item)
External - outdoor, indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Concurrent devices: 200+ , BSSIDs per radio: 4
Power Over Ethernet (PoE) Supported
PoE+
DC 44 - 57 V
19.67 cm x 19.67 cm x 3.5 cm
350 g
Packaged Quantity
Radio access point
Ruggedized Design
Outdoor, indoor
19.67 cm
19.67 cm
3.5 cm
350 g
External
Wireless
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Max Range Open Space
122 m
VLAN support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, 3T3R MIMO technology, ceiling mountable
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK, WEP
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
2 x 1000Base-T (PoE+) - RJ-45 , 1 x USB 2.0
IC, FCC
PoE+
DC 44 - 57 V
9 Watt
-10 °C
70 °C
5 - 95% (non-condensing)
Speed: 1300Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Compatibility: PC
Brand: Ubiquiti
Price Range Ex VAT: £500 - £750
