Ubiquiti Nanostation Loco M5
Quicklinx: C1SVWS00 Mfr#: LOCOM5
Ubiquiti Networks set the bar for the world's low-cost and efficient broadband Customer Premises Equipment (CPE) with the original NanoStation. The NanoStationloco take the concept to the future with sleek and elegant form factors, along with integrated airMAX (MIMO TDMA protocol) technology.
The low cost, high performance and small form factor of NanoStationloco makes it extremely versatile and economical to deploy.
  • Utilize airMAX technology
    Unlike standard Wi-Fi protocol, Ubiquiti's Time Division Multiple Access (TDMA) airMAX protocol allows each client to send and receive data using pre-designated time slots scheduled by an intelligent AP controller. This "time slot" method eliminates hidden node collisions and maximizes airtime efficiency. It provides many magnitudes of performance improvements in latency, throughput, and scalability compared to all other outdoor systems in its class.
  • Intelligent QoS
    Priority is given to voice/video for seamless streaming.
  • Scalability
    High capacity and scalability.
  • Long distance
    Capable of high-speed, carrier-class links.
  • Latency
    Multiple features dramatically reduce noise.
  • Dual Ethernet connectivity
    The NanoStation provides a secondary Ethernet port with software-enabled PoE output for seamless IP video integration.
Ubiquiti NanoStation loco M5 - wireless bridge - AirMax
Wireless bridge
External
1 x Atheros MIPS 24KC 400 MHz
RAM
32 MB
Flash Memory
8 MB
AirMax
Frequency Band
5 GHz
PoE injector, pole mount
Power Over Ethernet (PoE) Supported
PoE
8 cm x 3.1 cm x 16.3 cm
180 g
Wireless bridge
8 cm
3.1 cm
16.3 cm
180 g
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
32 MB SDRAM
Flash Memory
8 MB
External
Wireless
AirMax
Frequency Band
5 GHz
Quality of Service (QoS), pole mountable
IEEE 802.3af
Aerial
Antenna
Internal
Gain Level
13 dBi
1 x 100Base-TX (PoE) - RJ-45
FCC Part 15.247, RSS-210, IC, RoHS
PoE
5.5 Watt
OS Provided
AirOS
-30 °C
75 °C
5 - 95%
