U S Robotics USB-to-Serial Converter Cable
Quicklinx: 588BWS00 Mfr#: USR995700-USB
The USRobotics USB-to-Serial Cable allows you to use a computer's USB portto connect to the serial port of a modem or other RS232 device. This easy to install six foot cable uses no IRQs, so you can use multiple serial devices without IRQ conflicts.
USRobotics - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
RS-232
Data Transfer Rate
115.2 Kbps
No CPU
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
115.2 Kbps
Processor / Memory
No CPU
1 x RS-232 - 25 pin D-Sub (DB-25)
USB
1 x USB / serial cable - 1.83 m
