Turtle Beach VelocityOne Flight Control System
Quicklinx: HX3SWS00 Mfr#: TBS-0715-02
Hurry, only 1 left in stock!
£275.85 ex VAT
£331.02 inc VAT
Express delivery Order within the next 19 hours for delivery on Wednesday
Millions of gamers worldwide have trusted Turtle Beach for decades to deliver game-changing audio quality. Collaborating with world-class aeronautical engineers & Pilots, Turtle Beach enters into the flight sim category with the launch of Flight Simulator for Xbox.
The VelocityOne Flight Universal Control System delivers the most comprehensive, flight control solution to setup your own cockpit at home. Whether you're an experienced PC player or among the first to play Flight Simulator on Xbox Series X|S, VelocityOne Flight equips you with all the controls needed to navigate the skies.
  • Universal design
    VelocityOne Flight includes everything you need to get off the ground. The Included throttle quadrant with dedicated trim wheel, and a realistic yoke with integrated rudder controls equips every home-pilot with a full suite of controls right out of the box. Plus, experience immersive audio and coordinate your flight through the integrated headset audio jack.
  • Realistic yoke design
    True-to-life 180° yoke handle rotation tuned for smooth and precise adjustments of any aircraft. Built to last with a non-contact hall effect sensor in the yoke shaft, you'll have smooth control over long-term usage.
  • Modular throttle quadrant
    Dual lever and vernier controls along with 10 programmable buttons and an integrated trim wheel provide a realistic experience for both light aircrafts and heavy jets. Customize your throttle controls with included custom lever handles to match your preferred aircraft.
  • Status indicator panel
    Receive real-time status alerts and monitor essential cockpit, navigation and engine systems and warnings. Customize the color of the ambient light, and swap between two different panels to fine-tune the cockpit to your liking.
  • Integrated rudder controls
    Taxi, land and turn with ease using integrated rudder controls and toe brake buttons at your fingertips. Execute coordinated turns in the sky with ease and stay straight during takeoff and landing with dedicated rudder controls and make precise taxi maneuvers with integrated brakes.
  • Comprehensive controls
    Equipped with two POV & two HAT switches to toggle between multiple different camera views. 18 additional buttons included so you can navigate any aircraft in confidence and remap controls to your preference.
  • Flight management display
    The full color display with dedicated controls helps you learn and configure the system on-the-fly for Microsoft Flight Simulator. Easily switch between profiles for different aircrafts and use the training feature to familiarize yourself with each control so you spend less time on the tarmac, and more time in the air.
Turtle Beach VelocityOne Flight - yoke and throttle - wired
Yoke and throttle
Wired
Controls
Throttle, trim wheel
Headset port, rudder control, programmable buttons, 180° yoke rotation, flight management display, status indicator panel
PC, Microsoft Xbox One, Microsoft Xbox Series S, Microsoft Xbox Series X
Yoke and throttle
Wired
Controls
Windows 10
48.3 cm
18.3 cm
49.5 cm
4.5 kg
Brand: Turtle Beach
