Turtle Beach Stealth Ultra Controller
Quicklinx: HSDNWS00 Mfr#: TBS-0710-05
Wired / Wireless: Wired, Wireless
Compatibility: Android, PC, Microsoft Xbox Series X, Microsoft Xbox One + 1 more
£149.99 ex VAT
£179.98 inc VAT
The Turtle Beach Stealth Ultra gamepad redefines gaming with its versatile connectivity and precision controls. Designed for gamers who demand performance and flexibility, it offers the choice of wired or wireless play through USB, 2.4 GHz, and Bluetooth connections. The gamepad's AntiDrift thumbsticks, programmable buttons, and comprehensive control layout, including 2 thumb sticks, 4 action buttons, and more, provide a gaming experience tailored to your style.
Compatibility is key, and the Turtle Beach Stealth Ultra excels by supporting a wide array of platforms such as Android, Microsoft Xbox One, Xbox Series S, Xbox Series X, and PC. This ensures your gamepad is ready for action, no matter the system. Additional features like the 3.5 mm audio port for direct headset connection, Rapid Charge Dock for quick battery replenishment, and a detachable cable for easy portability, make the Turtle Beach Stealth Ultra the gamepad for serious gamers.
  • High-performance, lag-free wireless technology
    The proprietary, lag-free 2.4 GHz USB transmitter gives you the freedom to wirelessly connect to Xbox consoles, and Windows 10 and 11 PCs by either plugging the transmitter directly into the device, or into the charge dock. Plus, with built-in Bluetooth technology you can elevate your game experience on Android mobile devices and supported Smart TVs.
  • 30-hour battery life and rapid charge dock
    The low-profile charge dock provides up to 30 hours of wireless usage, and fully recharges in just 2 hours using USB 3.0 high-speed charging. The dock also has a USB port so you can plug the wireless transmitter into the dock so you're only taking up one USB port on your Xbox or PC.
  • Connected Command Display
    Unlike anything seen before in gaming, the dynamic full-color, Command Display dashboard keeps you connected with social media notifications, and extensive settings adjustments available right on the dashboard. Unleash the full potential of Stealth Ultra and save up to 10 profiles with customization of button mapping, dead zones and axis response modes, vibration intensity, audio enhancements, and RGB lighting.
  • Patented, on-board social notifications
    Receive social notifications from your phone for all your favorite social media platforms on the Command Display dashboard to keep you in the loop while gaming.
  • AntiDrift thumbsticks
    Contactless, hall effect thumbsticks use internal magnets instead of full contact analog-style sticks to provide high-resolution, smooth control without drift. You can even dial in stick performance to suit the exact game you're playing with linear input for consistent steering in racing games, or precision input for pinpoint aim in action and FPS games.
  • Precise, microswitch buttons
    The Stealth Ultra was designed with high-end components throughout to boost performance and longevity. Tactile microswitches in the D-Pad, ABXY cluster, mappable buttons and bumper buttons give every button a faster, more reliable response, and are rated at 5 million clicks, or up to 5x as long as standard buttons.
  • Adjustable trigger stops
    Modify the throw distance of the triggers on-the-fly to suit the games you play. Shorter hair trigger locks provide a faster return profile for FPS games or set to full travel for precise throttle and brake control when racing.
  • Four mappable quick-action buttons
    Four mappable microswitch buttons on the back of the controller allow you to set up the Stealth Ultra to your exact preferences depending on the types of games you play. Within the 10 onboard profiles available, you can set specific button mappings and settings for multiple games and loadouts.
  • Pro-Aim focus mode
    Selectable as one of preset functions for any of the four mappable buttons, Pro-Aim tunes thumbstick sensitivity for enhanced long-range accuracy. Whether it's a long-range snipe, or a daunting free kick, Pro-Aim is fully adjustable to dial-in the sensitivity just right.
  • Advanced audio tuning
    Enhance any 3.5 mm connected headset with easy access audio features only available from Turtle Beach including four EQ presets and Superhuman Hearing. Plus, you can set the game and chat volume mix to your exact preference, adjust mic monitoring and more, all directly from the Command Display dashboard.
  • Intelligent RGB lighting
    The intelligent RGB LED lighting system allows you to personalize the Stealth Ultra with 16.8 million distinct colors and effects. You can also set up different color combinations for notification alerts and low battery warnings to keep you in tune with product status.
  • Immersive vibration feedback
    Dual rumble motors in the handles and triggers provide immersive vibration feedback and are fully adjustable via the Command Display dashboard. Tune the levels of vibration to suit the games you play, from maximum vibration for intense racing games, to minimum feedback for reduced interference when precise aim control is needed.
  • Premium materials
    Designed for longevity and comfort, the Stealth Ultra has soft touch finishes, long-lasting microswitches, and comfortable, ergonomic grips.
  • Charge-through case
    Stow away your controller, charge dock, cables and included additional thumbcaps in the hardshell travel case, plus a built-in slot lets you charge your Stealth Ultra while in its case.
Turtle Beach Stealth Ultra - Rapid Charge Dock - gamepad - wireless, wired - 2.4 GHz/Bluetooth
Gamepad
Wireless, wired - 2.4 GHz/Bluetooth
Controls
A button, B button, X button, Y button, menu button, 4 action buttons, D-pad, 2 thumb sticks, bumpers, triggers
Connected command display, AntiDrift thumbsticks, 3.5 mm audio port, vibration-feedback, detachable cable, programmable buttons
Microsoft Xbox One, Microsoft Xbox Series X, Microsoft Xbox Series S, Android, PC
Gamepad
Controls
USB
Android 8.0 (Oreo) or later, Microsoft Windows 10 / 11
Rechargeable
USB to USB-C cable (3 m), storage case, sticker, 4 thumb caps
16 cm
12 cm
6.42 cm
246 g
Wired / Wireless: Wireless
Compatibility: PC
Compatibility: Microsoft Xbox Series X
Compatibility: Microsoft Xbox One
Compatibility: Microsoft Xbox Series S
Brand: Turtle Beach
