CrossPlay multiplatform wireless audio system
Dual USB wireless transmitters and a single button on the headset allow you to quickly switch between your favorite console or PC without having to move transmitters or connect cables. -
Simultaneous Wireless + Bluetooth
Connect to your gaming console or PC, as well as your smartphone or tablet at the same time with simultaneous 2.4 GHz Wireless and Bluetooth 5.2. With dual wireless capabilities, you can chat with friends, or listen to your favorite music from your phone and still hear game audio from your console or PC. Plus, with independent volume controls, you can easily adjust and mix the levels of wireless and Bluetooth audio sources. -
Stunning audio clarity
60 mm Eclipse dual drivers deliver immersive soundscapes with precision and deep bass. The dual drivers are designed with a distinct woofer and tweeter to separate low and high frequencies for vastly improved audio detail over conventional drivers. -
Exceptional microphone performance
Completely redesigned for the third generation of Stealth 700, the uni-directional, flip-to-mute microphone features A.I. noise reduction to ensure quiet background. -
Unstoppable, 80-hour battery life
Power through gaming sessions with a massive battery life of up to 80 hours. Plus, with a quick-charge, you can get back in the action right away with 3 hours of battery life in just a 15-minute charge. -
Superb comfort and durability
Designed for a comfortable fit that's built to last through every battle, the Stealth 700 features hybrid leatherette and athletic-weave fabric wrapped memory foam cushions, and durable steel-reinforced construction. Plus, the cushions feature ProSpecs glasses relief technology so every gamer can enjoy the same great comfort. -
Advanced Superhuman Hearing
Advanced Superhuman Hearing brings the same great battlefield advantage of Superhuman Hearing, but now with additional adjustability. -
Easy access to audio presets
Enhance your gameplay experience at the touch of a button with four Turtle Beach audio presets including Bass Boost, Signature Sound, Treble Boost, and Vocal Boost. -
Variable mic monitoring
Avoid shouting thanks to variable mic monitoring (or sidetone) which allows you to hear and adjust your voice through the headset while you chat.
- Turtle Beach Stealth 700 3rd generation - headset
- Product Type
- Headset - Bluetooth / 2.4 GHz radio frequency - wireless
- Recommended Use
- Game console, portable electronics, computer
- Gaming
- Cobalt blue
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Bass Boost, Vocal Boost, Treble Boost, Superhuman Hearing, Signature Sound, Spatial Audio
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphone Noise Cancelling
- Controls
- Power on/off, game volume, chat volume, flip-to-mute
- 1-year warranty
- Product Type
- Product Generation
- 3rd generation
- 9.4 cm
- 20 cm
- 17.3 cm
- 400 g
- Cobalt blue
- Earpad Material
- Leatherette, athletic weave fabric, memory foam
- Recommended Use
- Gaming
- Remapable wheel
- Packaging Type
- Retail box
Audio Output
- Full size
- Wireless
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Noise Isolating
- 20 - 20000 Hz
- Diaphragm
- 60 mm
- Adjustable Headband
- ProSpecs glasses relief system, dual driver
Microphone
- Boom
- Form Factor
- Built-in
- Uni-directional
- Noise Cancelling
- Noise Cancelling Technology
- AI noise cancelling
Remote Control
- Controls
- Software Included
- Swarm II
- Included Accessories
- USB-C charging cable, 2 wireless transmitters
- Cable Details
- USB-C charge cable - detachable - 70 cm
- Supported Host Device OS
- Windows 10 or later
- Battery
- Headset battery rechargeable - lithium polymer
- Run Time (Up To)
- 80 hour(s)
- Run Time Details
- Continuous playback (with 15 min charge): up to 3 hours
- Limited warranty - 1 year
- Shipping Width
- 21.6 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 11.1 cm
