Turtle Beach Stealth 700 Gen 3 · PS · White
Quicklinx: HT6TWS00 Mfr#: TBS-3101-15
£135.42 ex VAT
£162.50 inc VAT
Marketing description is not available.
  • CrossPlay multiplatform wireless audio system
    Dual USB wireless transmitters and a single button on the headset allow you to quickly switch between your PlayStation or PC without having to move transmitters or connect cables.
  • Simultaneous Wireless + Bluetooth
    Connect to your gaming console or PC, as well as your smartphone or tablet at the same time with simultaneous 2.4 GHz Wireless and Bluetooth 5.2. With dual wireless capabilities, you can chat with friends, or listen to your favorite music from your phone and still hear game audio on your console or PC. Plus, with independent volume controls, you can easily adjust and mix the levels of wireless and Bluetooth audio sources.
  • Stunning audio clarity
    60 mm Eclipse dual drivers deliver immersive soundscapes with precision and deep bass. The dual drivers are designed with a distinct woofer and tweeter to separate low and high frequencies for vastly improved audio detail over conventional drivers.
  • Exceptional microphone performance
    Completely redesigned for the third generation of Stealth 700, the uni-directional, flip-to-mute microphone features A.I. noise reduction to ensure quiet background and exceptionally clear voice accuracy.
  • Unstoppable, 80-hour battery life
    Power through gaming sessions with a massive battery life of up to 80 hours. Plus, with a quick-charge, you can get back in the action right away with 3 hours of battery life in just a 15-minute charge.
  • Superb comfort and durability
    Designed for a comfortable fit that's built to last through every battle, the Stealth 700 features hybrid leatherette and athletic-weave fabric wrapped memory foam cushions, and durable steel-reinforced construction. Plus, the cushions feature ProSpecs glasses relief technology so every gamer can enjoy the same great comfort.
  • Advanced Superhuman Hearing
    Advanced Superhuman Hearing brings the same great battlefield advantage of Superhuman Hearing, but now with additional adjustability.
  • Easy access to audio presets
    Enhance your gameplay experience at the touch of a button with four Turtle Beach audio presets including Bass Boost, Signature Sound, Treble Boost, and Vocal Boost.
  • Variable mic monitoring
    Avoid shouting thanks to variable mic monitoring (or sidetone) which allows you to hear and adjust your voice through the headset while you chat.
Turtle Beach Stealth 700 3rd generation - headset
Headset - Bluetooth / 2.4 GHz radio frequency - wireless
Recommended Use
Game console, portable electronics, computer
Gaming
White
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Bass Boost, Vocal Boost, Treble Boost, Superhuman Hearing, Signature Sound, Spatial Audio
Audio Specifications
Frequency Response 20 - 20000 Hz
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Uni-directional
Microphone Noise Cancelling
Controls
Power on/off, game volume, chat volume, flip-to-mute
1-year warranty
Product Generation
3rd generation
9.4 cm
20 cm
17.3 cm
400 g
White
Earpad Material
Leatherette, memory foam, athletic weave fabric
Recommended Use
Gaming
Remapable wheel
Packaging Type
Retail box
Audio Output
Full size
Wireless
Wireless Technology
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Noise Isolating
Frequency Response
20 - 20000 Hz
Diaphragm
60 mm
Adjustable Headband
ProSpecs glasses relief system
Microphone
Boom
Headset microphone
Uni-directional
Noise Cancelling
Noise Cancelling Technology
AI noise cancelling
Remote Control
Controls
Software Included
Swarm II
2 wireless transmitters, USB-C charging cable
Cable Details
USB-C charge cable - detachable - 70 cm
Supported Host Device OS
Windows 10 or later
Headset battery rechargeable - lithium polymer
Run Time (Up To)
80 hour(s)
Run Time Details
Continuous playback (with 15 min charge): up to 3 hours
Limited warranty - 1 year
Shipping Width
21.6 cm
Shipping Depth
22.5 cm
Shipping Height
11.1 cm
Brand: Turtle Beach
