Turtle Beach Stealth 300P
Quicklinx: G891WS00 Mfr#: TBS-3350-02
The Stealth 300 gaming headset delivers powerful game and chat audio through large 50 mm over-ear speakers and Turtle Beach's renowned high-sensitivity flip-to-mute mic. For added durability and unmatched comfort, the Stealth 300 dawns a metal-reinforced frame with Turtle Beach's unique ProSpecs glasses friendly design, along with a breathable fabric-wrapped headband and memory foam ear cushions. Additionally, the Stealth 300 offers Variable Mic Monitoring so you can hear and adjust the volume of your voice inside the headset to avoid shouting at other players, plus audio presets including Bass Boost, and a rechargeable battery that delivers over 30 hours of gaming per use.
  • Glasses friendly
    Turtle Beach's patented ProSpecs Glasses Relief System features dual-foam ear cushions, with softer foam in the section that rests against your glasses, alleviating pressure and allowing gamers with glasses to play in comfort.
  • Superior 50 mm speakers
    Hear every crisp high and thundering low with these large, powerful 50 mm over-ear speakers.
  • Audio presets, including Bass Boost
    Enhance your gameplay experience with four audio EQ presets including Bass Boost, Signature Sound, Bass and Treble Boost, and Vocal Boost.
  • Flip-up mic
    Turtle Beach's renowned high-sensitivity mic picks up your voice loud and clear to ensure your commands are always heard. Plus, it flips-up out of the way to Mute when not in use and blends into the headset's design.
  • Memory foam ear cushions
    Breathable fabric-wrapped memory foam ear cushions provide unmatched comfort.
  • Variable Mic Monitoring
    Say it... don't shout it, thanks to the ability to hear and adjust the volume of your own voice inside the headset to avoid shouting at teammates and other players.
Turtle Beach Stealth 300 - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Recommended Use
Game console
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Sound Effects
Bass Boost, Surround Sound, Crystal Clear
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Volume
Headband Material
Fabric, metal
Earpad Material
Memory foam
Recommended Use
Game console
Audio Output
Full size
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Sound Effects
Frequency Response
20 - 20000 Hz
Diaphragm
50 mm
Magnet Material
Neodymium
ProSpecs glasses relief system
Microphone
Boom
Headset microphone
Omni-directional
Mute function
Remote Control
Controls
Volume
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable Details
Headset cable
Headset battery rechargeable - lithium polymer
900 mAh
Run Time (Up To)
30 hour(s)
