Be the spark! The Turtle Beach Recon Spark gaming headset is built for performance delivering powerful sound and crystal-clear chat through its high-quality 40mm speakers and high-sensitivity flip-to-mute mic. The Recon Spark debuts a new white and lavender colorway and features a lightweight design, metal-reinforced headband, on-ear volume controls, and glasses friendly memory foam ear cushions, so you can play comfortably for hours. Additionally, the Recon Spark is designed for multiplatform compatibility featuring a standard 3.5mm connection ideal for use with Xbox One, PS4 Pro & PS4, Nintendo Switch, mobile devices with a 3.5mm headset jack, and PC gaming with included PC splitter cable.
Flip-up mic
Turtle Beach's renowned high-sensitivity mic picks up your voice loud and clear to ensure your commands are always heard. Plus, it flips up out of the way to Mute when not in use and blends into the headset's design. -
Glasses friendly
Turtle Beach's patented ProSpecs Glasses Relief System features dual-foam ear cushions, with softer foam in the section that rests against your glasses, alleviating pressure and allowing gamers with glasses to play in comfort. -
Multiplatform compatibility
Designed for Xbox One, PS4, Nintendo Switch, PC Gaming, and also works great with mobile devices. -
Metal-reinforced headband
A metal-reinforced headband provides added durability. -
High-quality 40MM speakers
Superior 40mm over-ear speakers deliver amazing game sound so you hear every crisp high and thundering low. -
Memory foam ear cushions
Synthetic leather-wrapped memory foam ear cushions provide long-lasting comfort. -
Onboard volume controls
Quickly adjust volume with convenient on-ear controls.
- Turtle Beach Recon Spark - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, portable electronics, computer
- White, lavender
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Volume, microphone on/mute
- Product Type
- White, lavender
- Headband Material
- Metal-reinforced
- Earpad Material
- Synthetic leather, memory foam
- Recommended Use
Audio Output
- Full size
- Wired
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium magnet
- Adjustable Headband
Microphone
- Boom
- Form Factor
- Headset microphone
- Omni-directional
Remote Control
- Controls
- Connector Type
- Headset (mini-phone 3.5 mm 4-pole)
- Included Accessories
- Sticker, audio splitter
- Cable Details
- Audio splitter cable - detachable , Headset cable
