Turtle Beach Recon Controller - White
Quicklinx: HLG1WS00 Mfr#: TBS-0705-02
£33.33 ex VAT
£39.99 inc VAT
The Turtle Beach Recon Controller for Xbox Series X|S and Xbox One is the first controller to pair game-changing audio innovations with game-winning controls. Plug in a 3.5mm headset and take advantage of proven Turtle Beach audio features like Superhuman Hearing, Mic Monitoring, Signature Audio Presets and more. Win more with Pro-Aim Focus Mode, which tunes thumbstick sensitivity for enhanced long-range accuracy, and save up to four selectable profiles on each of the two, rear quick-action buttons. Play for hours in comfort thanks to ergonomic cooling grips and feel every vital gaming detail with next-gen vibration feedback in the handles and triggers. The Turtle Beach Recon Controller for Xbox Series X|S and Xbox One is the first controller to pair game-changing audio innovations with game-winning controls.
  • Turtle Beach audio advantage
    Easy-access audio controls only available from Turtle Beach including EQ presets, game and chat volume mix, mic monitoring and more.
  • Two mappable quick-action buttons
    Customize your gaming experience with two mappable buttons, allowing up to four different switchable profiles.
  • Four Turtle Beach signature presets
    Customize your game audio with four EQ presets: Signature Sound (Default) Bass Boost, Bass and Treble Boost and Vocal Boost.
  • Vibration feedback
    Dual rumble motors in the handles and triggers enhance immersion for ultra-realistic next-gen gameplay.
  • 3.5mm headset connection
    Take advantage of proven Turtle Beach audio enhancements by plugging in any 3.5mm connected headset.
  • Mic monitoring
    Hear and adjust the volume of your own voice to avoid shouting while you chat for clear communications.
  • Responsive controls
    Play in confidence with textured triggers and bumpers, an accurate 8-way D-pad, and smooth thumbstick movement.
  • Wired to win
    Equipped with a detachable 10 ft./3m braided cable with USB-C connector.
Turtle Beach Recon Controller - gamepad - wired
Gamepad
Wired
Controls
8-way D-pad, action buttons, triggers, bumpers
Vibration-feedback, headset port, Dual Rumble Motors
White
1-year warranty
PC, Microsoft Xbox One, Microsoft Xbox Series S, Microsoft Xbox Series X
Gamepad
Wired
Controls
USB
White
Windows 10
USB-C cable (3 m)
18.3 cm
18 cm
7.3 cm
300 g
Limited warranty - 1 year
Type: Game pad
Wired / Wireless: Wired
Compatibility: Microsoft Xbox One
Compatibility: Microsoft Xbox Series X
Compatibility: Microsoft Xbox Series S
Brand: Turtle Beach
