The Turtle Beach Recon Controller for Xbox Series X|S and Xbox One is the first controller to pair game-changing audio innovations with game-winning controls. Plug in a 3.5mm headset and take advantage of proven Turtle Beach audio features like Superhuman Hearing, Mic Monitoring, Signature Audio Presets and more. Win more with Pro-Aim Focus Mode, which tunes thumbstick sensitivity for enhanced long-range accuracy, and save up to four selectable profiles on each of the two, rear quick-action buttons. Play for hours in comfort thanks to ergonomic cooling grips and feel every vital gaming detail with next-gen vibration feedback in the handles and triggers. The Turtle Beach Recon Controller for Xbox Series X|S and Xbox One is the first controller to pair game-changing audio innovations with game-winning controls.
Turtle Beach audio advantage
Easy-access audio controls only available from Turtle Beach including EQ presets, game and chat volume mix, mic monitoring and more. -
Two mappable quick-action buttons
Customize your gaming experience with two mappable buttons, allowing up to four different switchable profiles. -
Four Turtle Beach signature presets
Customize your game audio with four EQ presets: Signature Sound (Default) Bass Boost, Bass and Treble Boost and Vocal Boost. -
Vibration feedback
Dual rumble motors in the handles and triggers enhance immersion for ultra-realistic next-gen gameplay. -
3.5mm headset connection
Take advantage of proven Turtle Beach audio enhancements by plugging in any 3.5mm connected headset. -
Mic monitoring
Hear and adjust the volume of your own voice to avoid shouting while you chat for clear communications. -
Responsive controls
Play in confidence with textured triggers and bumpers, an accurate 8-way D-pad, and smooth thumbstick movement. -
Wired to win
Equipped with a detachable 10 ft./3m braided cable with USB-C connector.
- Turtle Beach Recon Controller - gamepad - wired
- Product Type
- Gamepad
- Connectivity Technology
- Wired
- Controls
- 8-way D-pad, triggers, bumpers, action buttons
- Vibration-feedback, headset port, Dual Rumble Motors
- White
- 1-year warranty
- Designed For
- Microsoft Xbox Series X, Microsoft Xbox One, PC, Microsoft Xbox Series S
- Product Type
- Gamepad
- Wired
- Controls
- Interface
- USB
- White
- OS Required
- Windows 10
- Included Accessories
- USB-C cable (3 m)
- 18.3 cm
- 18 cm
- 7.3 cm
- 300 g
- Limited warranty - 1 year
- Designed For
