Built for your next Victory Royale, your latest achievement and much more with the Turtle Beach RECON 70 gaming headset for PS4 Pro and PS. Featuring Turtle Beach's lightweight and comfortable headset design for hours of play, with high-quality 40mm speakers and over-ear premium synthetic leather cushions that let you hear every crisp high and thundering low while blocking noise. Turtle Beach's renowned high-sensitivity mic to ensure you are heard clearly and easily flips up to mute. Finally, the versatile 3.5mm connection makes it perfect for swapping between PS4 and Xbox One controllers, Nintendo Switch as well as PC and compatible mobile devices.
Lightweight comfort
A lightweight headset design ensures complete comfort during those hours-long gaming sessions featuring a padded headband and ear cushions. -
Flip-up mic
Turtle Beach's renowned high-sensitivity mic picks up your voice loud and clear to ensure your commands are always heard. Plus, it flips up out of the way to Mute when not in use and blends into the headset's design. -
High-quality 40mm speakers
Superior 40mm over-ear speakers deliver amazing game sound so you hear every crisp high and thundering low. -
Premium ear cushions
Synthetic leather-wrapped ear cushions provide added comfort, improved bass response and better noise-isolation. -
Multiplatform compatibility
Designed for PS4 Pro & PS4 controllers with a 3.5mm jack and also works great with Xbox One, Nintendo Switch, PC, and mobile devices with a 3.5mm connection.
- Turtle Beach Recon 70 - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, computer
- Blue camo
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Volume, microphone on/mute
- Product Type
- Blue camo
- Headband Material
- Leatherette
- Earpad Material
- Foam
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Omni-directional
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1.2 m
- Included Accessories
- Turtle Beach sticker
- Cable Details
- Headset cable - 1.2 m
