Turtle Beach Fuel VR Charger for Meta Quest 2 - Grey
Quicklinx: H732WS00 Mfr#: TBS-0040-05
Type: Charger
Hurry, only 2 left in stock!
£57.66 ex VAT
£69.19 inc VAT
  • Rechargeable Controller Battery Packs - Dual battery packs deliver 20-hours of battery life per pack and eliminate the need for environmentally harmful, disposable batteries.
  • Simple Magnetic Charging - Slotted battery door covers on the controllers and USB-C to magnetic pin dongle for headset make for easy magnetic charging in just 2.5 hours.
  • Complete, Compact Design - Charge your entire Meta Quest 2 VR setup all at once while taking up minimal space on your desktop or gaming setup thanks to a compact design.
  • Efficient charging
    With a capacity of 1500 mAh and a quick charge feature, this charging dock ensures your virtual reality headset and controller are ready to use in just 2.5 hours. The LED battery indicator provides real-time charging status, making it easier to manage your device's power needs.
  • Convenient design
    The compact design of this charging dock, accompanied by a 2 m USB-C cable, offers a seamless integration into any gaming setup. Its ability to support both the virtual reality headset and controller with a single 24-pin USB-C output connector simplifies the charging process.
  • Reliable power solution
    Included with an AC power adapter, this charging dock represents a complete power solution for your virtual reality devices. Its design specifically for virtual reality headsets and controllers ensures compatibility and optimal charging efficiency.
Turtle Beach charging dock - + AC power adapter - with battery - 2 - 24 pin USB-C
Charging dock + AC power adapter + battery
22.5 cm x 7.39 cm x 20.6 cm
1 kg
Output Connector Type
24 pin USB-C
1500 mAh
Cables
USB-C cable - 2 m
Batteries Included
2 pcs.
Charging dock + AC power adapter battery
Virtual reality headset controller, virtual reality headset
22.5 cm
7.39 cm
20.6 cm
1 kg
Output connectors
24 pin USB-C
AC Power Adapter Included
Compact design, quick charge, LED battery indicator
Included Qty
2
1500 mAh
Run Time (Up To)
20 hour(s)
Recharge Time
2.5 hour(s)
2 rechargeable batteries, 2 battery doors
USB-C cable - 2 m
Type: Charger
Brand: Turtle Beach
