Turtle Beach Atlas One
Quicklinx: G89NWS00 Mfr#: TBS-6200-02
Built for PC! The Turtle Beach Atlas One gaming headset delivers comfort driven performance with immersive Windows Sonic surround sound and crystal-clear chat through its high-quality 40mm speakers and high-sensitivity flip-to-mute mic. The Atlas One also features a lightweight design with a metal-reinforced headband and glasses friendly synthetic leather-wrapped memory foam ear cushions to provide added durability and unmatched comfort. Additionally, while the Atlas One is designed for PC gaming, it's standard 3.5mm connection also makes it great to use with Xbox One, PS4 Pro & PS4, Nintendo Switch, and mobile devices with a 3.5mm headset jack.
  • Flip-up mic
    Turtle Beach's renowned high-sensitivity mic picks up your voice loud and clear to ensure your commands are always heard. Plus, it flips up out of the way to Mute when not in use and blends into the headset's design.
  • Glasses friendly
    Turtle Beach's patented ProSpecs Glasses Relief System features dual-foam ear cushions, with softer foam in the section that rests against your glasses, alleviating pressure and allowing gamers with glasses to play in comfort.
  • Metal-reinforced headband
    A metal-reinforced headband provides added durability.
  • Memory foam ear cushions
    Synthetic leather-wrapped memory foam ear cushions provide long-lasting comfort.
  • High-quality 40mm speakers
    Superior 40mm over-ear speakers deliver amazing game sound so you hear every crisp high and thundering low.
  • Multiplatform compatibility
    Designed for PC Gaming, and also works great with Xbox One, PlayStation 4, Nintendo Switch, and mobile devices with a 3.5mm connection.
Turtle Beach Atlas One - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Mute, volume
1-year warranty
Headband Material
Leatherette, memory foam
Earpad Material
Synthetic leather, memory foam
Recommended Use
Audio Output
Full size
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Diaphragm
40 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Omni-directional
Remote Control
Controls
Mute, volume
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable Details
Headset cable , Audio splitter cable
Limited warranty - parts and labour - 1 year
