Trust TB-7300 Wide Tablet
Customer rating: 4.0* (Write a review)
Quicklinx: 54ZTWS00 Mfr#: 15358
Marketing description is not available.
Trust Wide Screen Design Tablet TB-7300 - digitiser
Digitiser
Wired
Buttons Qty
32
Programmable buttons, zoom wheel, scrolling wheels (2-way), volume control, Dual Mode Pad
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
Digitiser
Input Device
Wired
Buttons Qty
32
Pressure Levels
1024
Active Area
30.5 cm x 19.5 cm
Cradle, nib removal tool, 2 ink tips, AAA battery
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM, USB port
Customer reviews
Write a review for the Trust TB-7300 Wide Tablet here!
Great value tablet
Reviewed by Anonymous Review Posted 25/06/2009
Had one of these for about a year and was just about to buy another one when I noticed the negative review so I though I'd add my experiences. The unit has worked perfectly since the day I installed it, I don't think I've changed the battery yet so that's not really that much of drawback. The accuracy of the tablet is very good even in absolute mode where the tablet represents your exact screen area. I use it to cut items out in Photoshop as part of my job so I need an accurate tablet and it's perfect. I found the macro function round the edge rather annoying but you can just turn them off in the software. All in all a great buy which is why I'm about to buy another one for my boss.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent
Reviewed by Anonymous Review Posted 22/01/2009
Great tablet no problems here, Photoshop 64bit wont work with it, and nibs wear out fast, maybe cos I just love using it so much, great specs. Very precise and look professional, give me £300 for a wacom and I'd by 3 of these and give 2 away haha.
  • Overall 5*
  • Ease of use 5*
Excellent product for the price
Reviewed by Richard. Review Posted 23/01/2009
Luckily, I had no problems like the other reviewer, and would highly recommend this product.
It's larger than you think with an active area just shy of an a4 piece of paper.
Wheels are handy, response is good, overall a very good tablet and a brilliant price.
Easily switch between wheel functions and widescreen/4:3 modes.
Cons:
Avoid using with multiple screens for any drawing as you get stretched images!
Macro editing software could do with work, but you'll figure it out and start adding your own shortcuts in no time.
Wire comes out the top of the tablet, so is difficult to fit a keyboard right up against the top.
Pen requires it's own battery (supplied) which is the classic mark of any cheap tablet!
Don't bother with Vista's built in tablet PC functions, useless! Just put it into normal tablet mode.
  • Overall 4*
  • Ease of use 4*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
