Tripp Lite Switched ATS / Auto Transfer Switch provides a redundant power option for single-corded network devices. Dual input cords support separate connection to PRIMARY and SECONDARY power sources. The ATS will normally maintain continuous output to all outlets as derived from the primary input cable. If the primary power source becomes unstable or fails altogether, the ATS will switch over to the secondary power source until the primary input is restored and stable. Switched PDU features include individually controllable output receptacles and built-in network interface. Super-fast switchover between primary and secondary power sources occurs within milliseconds. ATS functionality is supported by any two compatible AC power sources, regardless of phase angle, to support a variety of advanced redundant power networking applications. Enables fault tolerant hot-swappable UPS protection when used with a single UPS and fully redundant UPS protection when each cord is connected to a separate UPS system. In a two-UPS environment, the primary input cable must be supported by a full time sine wave UPS with zero transfer time. Tripp Lite SmartOnline series is highly recommended for use as the primary UPS in a two-UPS application. ATS configurations utilizing separate mains circuits, backup generators and even separate utility power grid feeds are fully supported. On-board ATS processor constantly evaluates power quality on both input sources to prevent transfer to the secondary source when unavailable or of lower quality than the primary source. Front input LED's display primary or secondary power availability.
Efficient power distribution
The Eaton Tripp Lite Series PDU Switched ATS 200-240V 16/20A offers an efficient solution for power distribution in high-density IT environments. With 8 C13 and 2 C19 outlets, it accommodates a wide range of equipment, ensuring reliable power delivery to critical systems. -
Advanced remote management
Equipped with Ethernet connectivity and support for SNMP protocols, this power distribution unit allows for comprehensive remote management. Users can monitor and control power distribution, ensuring optimal performance and immediate response to any issues. -
Seamless power redundancy
Featuring Automatic Transfer Switch (ATS) technology, the unit provides seamless switching between two power sources, ensuring uninterrupted power supply to connected devices. This critical feature enhances system reliability and protects against power interruptions.
- Eaton Tripp Lite Series PDU Switched ATS 200-240V 16/20A 8 C13 2 C19 C20 Horizontal 1URM - horizontal rackmount - power distribution unit - 3.8 kW
- Power distribution unit - rack-mountable
- Rack Size
- 1U
- 4.7 kg
- Input Voltage
- AC 200-240 V
- Output Voltage
- AC 200/208/220/230/240 V
- Power Capacity
- 3.8 kW
- Input Connectors
- 2 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 ¦ 2 x power IEC 60320 C19
- Networking
- Ethernet
- Remote Management Protocol
- SNMP
- Black
- 43.9 cm x 37.6 cm x 4.4 cm
- 2-year warranty
- Height (Rack Units)
- 1U
- Black
- Input Voltage
- AC 200-240 V
- Frequency Provided
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200/208/220/230/240 V 50/60 Hz
- Max Electric Current
- 16 A
- Power Capacity
- 3.8 kW
- Remote Management Interface
- Ethernet
- SNMP
- Cables Included
- 2 x power cable
- LED display, current meter, LED indicators, Automatic Transfer Switch (ATS)
- NOM, UL 60950, RoHS
- Limited warranty - 2 years
- 0 - 95%
- 43.9 cm
- 37.6 cm
- 4.4 cm
- 4.7 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 53.3 cm
- Shipping Height
- 13.5 cm
- Shipping Weight
- 9.1 kg
